MSI A520M A-PRO Solved!
Status
Not open for further replies.
nayem2000
I have taken second pc as AMD and took MSI A520M-A PRO Motherboard. From the very first day i have faced issues.
The issues i have faced and facing:
01.Chaning Ram cause problem.
02. Changing SSD or Adding SSD / HDD cause problem
Which i installed first time that is ok but if i add extra it shows problem. sometime after installing windows fix issues sometime removing device fixed issues.
Last day when i changed RAM and tried to add and Extra HDD with Nvme it always takes me to boot menu. Then even after removing everything it takes me to boot menu again and again nothing else was showing but boot menu/bios menu.
After so many attempts i tried to install widnows then after installing windows i kept extra ram and the pc was ok which was not ok before new windows install, after then when i added the HDD it shows the same issue, everytime taking me to boot menu. then i removed the HDD and this time pc is running.
I have never faced these types of issues with gigabyte, intel, or asus but MSI given me the worst experience ever.
If you guys can tell me something about.
Thanks.
Spec:
MSI A520M-A PRO
AMD Ryzen 5 5600G​
RAM 3200Mhz 1X16GB 1X8GB
Nvme 256GB
SSD 256GB
PSU : MAG A500DN - 500 Watt
Updated the bios just a bit ago but the problem still same! :(
Thanks.
Spec:
MSI A520M-A PRO
AMD Ryzen 5 5600G​
Nvme 256GB
SSD 256GB
The info you provided is pretty generic for your components. Really hard to evaluate very much based on that info.
See : >>Posting Guide<<
Status
