MSI AFTER BURNER RESET TO DEFAULT WHEN APPLYING
ianisnm154e02da
when I try to give the maximum the two boxes from the clock,give save and after give apply and they return to normal
Alan J T
Demon God
Sounds like it is resetting to Defults may be caused by an unstable OC setting
Moving sliders to MAX and applying the setting is not how it works 99% of the time this will fail to work
Try moving the slider just a bit like 25 Mhz at a time
Alan J T
Demon God
Hello ! Something like that shows me as in this clip (https://www.youtube.com/shorts/VXr98s__xO8) only that both boxes come back to me
Can you list your Hardware, please
>>Posting Guide<<
AfterBurner Help Forum is here
MSI AfterBurner Problems
I can verify it is working with out a problem on my System
AMD Ryzen 5 7600X
MSI MPG X670E CARBON WIFI
BIOS MS-7D70v16 AGESA 1.0.0.6
RAM Corsair Vengence 16GBx4 P/N: CMH32GX5M2B6000Z30
Total Size 64GB @6000-Mhz
Quad Channel DDR5-SDRAM
Timings 30-36-36-76-112
AMD Radeon RX 6900 XT
GPU Brand ASUSTeK Computer Inc.
Storage
MSI M480 1TB x4
AMD-RAID Capacity 15GB
4x2-TB and 2x4-TB SSD SATA 111
Monitor 1 P150FIT (ASM150F)
15 inches (38.1 cm) / 1920 x 1080 pixels @ 60Hz
Monitor 2 Kogan TV (KON0030)
52 inches (132.1 cm) / 3840 x 2160 pixels @ 60Hz
Edition Windows 10 Pro
Version 22H2- build 19045.2788
Windows Feature Experience Pack 120.2212.4190.0
