MSI Afterburner and Audio Stutter
benhees14fa02c7
First off I want to say I enjoy using MSI Afterburner and its features. I don't use it because while it is installed all audio gets stutters and distortion while it is installed.
I know this is not an MSI laptop and that may be the reason.
Operating System: Windows 10 Home 64-bit (10.0, Build 19041) (19041.vb_release.191206-1406)
System Manufacturer: Dell Inc.
System Model: Inspiron 7591 2n1
BIOS: 1.6.1 (type: UEFI)
Processor: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz (8 CPUs), ~2.3GHz
Memory: 65536MB RAM
Available OS Memory: 65320MB RAM
Card name: Intel(R) UHD Graphics
GPU processor: GeForce MX250
Driver version: 451.67
Driver Type: DCH
Direct3D API version: 12
Direct3D feature level: 12_1
CUDA Cores: 384
Core clock: 1518 MHz
Memory data rate: 7.01 Gbps
Memory interface: 64-bit
Memory bandwidth: 56.06 GB/s
Total available graphics memory: 34708 MB
Dedicated video memory: 2048 MB GDDR5
System video memory: 0 MB
Shared system memory: 32660 MB
Video BIOS version: 86.08.3B.00.01
IRQ: Not used
Bus: PCI Express x2 Gen3
Device Id: 10DE 1D13 09501028
Part Number: 2902 0100
Perhaps with the above information one can provide an answer or this can spark discussion for solutions.
Big mac
Big mac
SECOND LIEUTENANT
Do you mean if you reinstall the MSI Afterburner the audio would normal?
As I know, MSI Afterburner only supports some specific laptops.
I suggest you clean install the relative audio driver (Realtek audio driver, Nahimic, Nahimic driver, and Realtek audio console).
Follow the below FAQ.
https://www.msi.com/faq/notebook-3640
benhees14fa02c7
No I have left it uninstalled because it effects even the ding from the audio system tray. I have done fresh install of windows multiple times. Fresh install of MSI Afterburner multiple times. Adjusted audio bit rate. Reinstalled, updated audio and graphics drivers various versions.
Big mac
Big mac
SECOND LIEUTENANT
What laptop are you using?
Could you provide the system information via the MSI help desk?
benhees14fa02c7
If you view my original post you would find the information you are looking for.
Add to note many people use MSI Afterburner for its ability to display graphics statistics onscreen, it is beneficial therefore on a variety of hardware.
Also your link to the FAQ goes to a blank page.
benhees14fa02c7
I have tried to run the MSI help desk app it is unable to obtain a system information simply because this is not a MSI laptop.
