Msi Afterburner fan curve does not apply at startup
hennigolsen
This topic bothers me as I have used countless hours trying to fix the problem with no luck. My undervolting profile seems to work, but the problem is that I just cant get the fan curve to activate at startup.
I have to manually go in and either apply profile again or disable/enable "enable user defined software automatic fan control". Then the fan curve will apply correctly.
Hardware:
-GIGABYTE GeForce RTX 5070 Ti WindForce 3 - 16GB GDDR7
-ASUS TUF GAMING B850-PLUS
There are several posts online on this topic, but most of them have easy fixes like "apply at startup in settings" or enabling Auto and User define.
What I have tried (and done):
-Disabled Windows (and Bios) fast boot​
-Delayed startup on Afterburner via Task Scheduler (30 sec) and via MSIAfterburner.cfg​
-Uninstalled potential conflicting apps (armoury crate gpu tweak etc)​
I hope its just a silly thing I forgot, but i suppose its not..​
Here are my settings in Afterburner:
