MSI Afterburner not showing correct temps
i have a problem with MSI afterburner, i'm using it to modify my GPU vents speed and it's working with the GPU temps
But on the screenshot that i give you, my MSI temps doesnt match my real GPU temps on the top, so my GPU vents are not working as intended.
Did u already have this kind of problem ? Maybe u have a solution ?
Thanks for the Answer and the reading :D
I'm experiencing the same issue. GPU-Z and MSI Kombustor provides the temperatures that are normal, in MSI Afterburner the temperature is just a flat line.
When I start my PC, Afterburner detects CPU usage and temperatures correctly, but not GPU. The GPU temperature detection system remains stuck on the initial boot temperature, and this causes the fans to stay idle even during gaming. When I restart my PC, it starts correctly. Is the driver problem you are talking about?
Yes.
See my hot fix post above yours. Hopefully, this issue is now fixed.
