MSI Alpha 15 Upgrade & Warranty
gora.biswa127102a3
My Laptop is not turning on, whenever I plug-in the power cable and press the power button only blue keyboard backlight turns on, and that's all no booting and blank display, even external monitor did not work
It wasn't like this from the start, I am a content creator and I am loosing my projects due to this, please help
If I want to upgrade Ram and SSD then there is a factory Seal on the back I have to remove to open the back cover.
Will it void my laptop's warranty?
Downey Rob
Try to perform EC reset. If it is not working, you should remove SSD, try backing up your important data, and send it to the service center for repair.
BTW, you should ask the service center about the warranty policy.
