- Mar 26, 2014
[Taipei, Taiwan] When Industry 4.0 is in progress, MSI has been providing robots and industrial computer equipment for intelligent manufacturing based on its strengths accumulated in many years in the field of cutting-edge technology. "MSI has devoted itself to the research and development of robots and smart automation control for many years. It has been applied in intelligent manufacturing with AIoT introduced to meet the needs of various automation applications, reducing production costs and enhancing quality assurance as well as to solve the shortage of manpower, improve the manufacturing process, extend the operating time of the equipment, improve the manufacturing efficiency, and reduce the risk of equipment damage," said Sam Chern, MSI Marketing Vice President.
MSI arrays its fleet of AMR robots
AMR-AI-Logistics Robot
Based on the concept of smart cabinets and smart autonomous mobile robots, it has a sound AMR smart transportation system and a variety of sensing devices to provide the premium service. It has a background management system and remote control, ensuring all goods are saved and retrieved with safety. You can set when and where to deliver the goods, a new smart and innovative logistics service that collects the goods within 24 hours. In addition, a variety of identification devices equip Barcode, QRcode and RFID feature for third-party management integration to provide the most user-friendly service. The AMR-AI-Logistics Robot has the ability of cross-floor distribution, which can autonomously get the access and elevators control to reach designated floors.
AMR-AI-Base Robot
The AMR-AI-Base Robot is an autonomous mobile assistive robot that can help move goods weighing up to 150KG. It can autonomously assist while reducing complicated and repetitive manual work. In addition, two new LDS laser navigation systems placed on the front and back of the robot can fully and autonomously recognize the environment and produce a map of the area, and routes can be set in any environment. With its high-precision positioning technology, the robot can avoid any obstacles with precise movement. It also has a powerful ability to automatically generate maps so it can adapt to any changing environment. The AMR-AI-Base Robot can be customized and equipped with add-on devices to serve in semiconductor production lines, logistics transportation, and factory automation. It effectively increases productivity, improves product quality, and helps companies rethink their optimization of the use of employee creativity and problem-solving, while also ensuring their safety.
AMR-AI-PJ-UVGI Robot
This intelligent AMR disinfection robot has been verified by the European research institute Texcell. Its UVGI sterilization system can effectively suppress the novel coronavirus (SARS-COV-2) in just 30 seconds, with a sterilization rate as high as (Log4) 99.997%. It is an autonomous mobile UV sterilization robot dedicated to air cleaning, disinfection, and cleaning that targets areas with high contact rates and a high flow of people. It helps reduce the risk of exposure to harmful viruses and bacteria, making it suitable for use in medical institutions, restaurants, schools, companies, retail, and transportation. With its complete AMR smart hospital transportation system, and equipped with a super 253.7 nm wavelength UVGI germicidal lamp, which can carry out detoxification operations over a wide area, it can effectively eliminate pathogens in the proximate environment of the robot. Establishing spatial landmarks and route maps using camera-assisted algorithms and automatic software calibration, it can actively carry out operations in the scheduled area, providing more labor-saving and effective tools for personnel and eliminating blind spots in disease prevention.
AMR-AI-Delivery Robot
The AMR-AI-Delivery Robot is an autonomous mobile delivery robot that can help deliver goods weighing up to 150KG. It can autonomously assist while reducing complicated and repetitive manual work. Using the AMR Fleet Management System, the robot can deliver to different levels of buildings and is equipped with customized IoT network equipment, which can independently control access to doors and elevators to reach designated floors. In addition, with new generation LDS modules and Intel RealSense depth cameras, you can set a travel route for the robot in any environment, calculate complex data for real-time analysis of the on-site environment, easily avoid obstacles, and achieve fully autonomous navigation. It is suitable for factories, warehouses, companies, care centers, shopping malls, and other areas.
Three Major Applications of MSI IPC Smart Factory Equipments
In-vehicle PC
MSI's in-vehicle computer MS-9B17 is E-Mark certified for in-vehicle applications and can be applied to the in-vehicle IC system of intelligent forklifts, connecting the intelligent safe driving monitoring system to improve driving safety and reduce serious accidents caused by human error. It can also plan routes and remotely contact storage systems.
Automation
MSI MS-9A89 ultra-low-power, fanless, wide-operating-temperature industrial computer provides powerful edge computing capabilities and integrates a variety of perception and control capabilities, such as vision and motion control. It can work in harsh environments such as high temperatures and dust to perform more diverse and multi-tasking operations.
Digital Signage Player
MSI MS-9A79 digital signage system is a thin and rugged industrial computer that provides more powerful performance, up to two independent displays, and an abundant and diverse number of connection interfaces. Its unique design that includes heat dissipation, shock resistance, and dust proofing can withstand any harsh application environment. It is the ideal solution in the field of industrial control automation.
MSI AIoT: https://www.msi.com/to/aiot
MSI AIoT Facebook : https://www.facebook.com/MSIAIoT
MSI AIoT Linkedin:https://www.linkedin.com/showcase/msi-aiot
MSI Global YouTube:https://www.youtube.com/user/MSI
Subscribe to MSI RSS Feeds via https://www.msi.com/rss for real-time news and more product info.
About MSI AIoT
MSI integrated server in conformity to the cloud idea, satisfy the needs of customers in industrial computers, introduced robots for AI living and realized automotive electronics with human technology to provide the optimum solution of AIoT. It is also a leading brand in AI, business, and IoT market. For more product information, please go to https://www.msi.com/
●All rights of the technical, pictures, text and other content published in this press release are reserved. Contents are subject to changes without prior notice.
AMR-AI-Base Robot
In-vehicle PC
Automation
About MSI AIoT
