msi b360-f pro Dram fail restart
n.darnak158302df
hi
This motherboard has the 4 debug lights and here's what happens:
CPU light first is fine, lights up and goes off, moves onto Ram light.
1 of 2 things happen: If I have no ram inserted, the Ram debut light stays on, and the power stays on. If I have ram in, the ram light goes off, the cpu light flashes, and the power restarts. It just goes into this cycle.
cpu ; i3 8100
ram; 8gb 2133 MHz 2666
Pro
Please list all your hardware (other cards, PSU...).
Did this start to happen recently? Only since you changed RAM? Bit more background information would be good.
n.darnak158302df
The motherboard is new, its first day. I installed the
Processor, RAM, and power supply. gpu rx 580 8gb
CPU light first lights up and goes off, moves onto Ram light. and restarts
psu : msi 750i gold
ram 1 ; 2666 MHz RAMAXEL
ram 2; 2133 MHz ADATA
cpu ; i3 8100
gpu ; rx 580 8gb
Pro
You are mixing RAM for dual-channel? This won't work well. You need an identical kit of two modules. Try with just just one RAM module in the left slot (as you only have two slots).
If that works, then update the BIOS to the newest version and try again with two modules. But it might be that it won't work properly unless you use a kit of identical modules.
n.darnak158302df
I only use one ram, another ram for my test, but the same problem
In other motherboard RAM works fine
I can't install versions of BIOS for me, my motherboard didn't work
Is there a defect in the motherboard
Pro
What do you mean, you can't update the BIOS?
Update how-to:
1) Get the latest BIOS. It's always the topmost one when you click on "BIOS" on the MSI support page for the mainboard.
2) Extract the file onto a USB stick.
4) Once M-Flash (the updater) is loaded, it will show a list of your drives. Select the USB stick and select the previously extracted file on there.
n.darnak158302df
I bought a new RAM , the motherboard did not work. same problem
Hynix HMA81GU6CJR8N-VK 8GB DDR4 2666MHz
Pro
I would take off the heatsink, take out the CPU, then inspect the CPU contacts and the socket for any anormalities, bent pins, or foreign objects. Clean the CPU and the heatsink base with a suitable cleaning agent (high-purity isopropyl alcohol, "rubbing alcohol", or specialized products like Arctic Silver ArctiClean). Put the CPU back in, apply a rice-grain to pea-sized blob of new heatpaste in the middle of the CPU heatspreader, put the cooler back on, and see if it fixed it.
n.darnak158302df
Thanks for the reply
I didn't find any twisted legs or dirt left in a socket .. A new motherboard,
The strange thing is that I am installing an i3 9100f processor. The LED stops at my devise. But me without a picture only a black picture
I just bought an i3 8100 processor to upgrade the BIOS
msi b360-f pro s/n: 601-7b25-010b1803005249
Pro
There's a few more things you could try. For example, take the board out and put it on a wooden table, this ensures that there are no shorts with the case.
Try with a different PSU. Take out the CMOS battery for a while.
