Hi Guys This is my build i been using it for 4 years Recently i face a problem that my display turn off and GPU fans start running at maximum speed suddenly I think and make noise while the computer keep working and don't turn off (if a video was playing it keep playing) then i had to turn it off from psu if i try to turn it on again it stop on VGA Ez Debug Led.
What i try to solve this problem
Check ram (swap them change slots)
Check GPU cable (change it to new one)
Use new GPU cable
Update BIOS from MSI center (it failed when the computer restart) then try to update it via M-Flash it went well (even the display turn off while flashing bios)
Format computer (display went off in update step on format)
Sometimes the computer works just fine for one day or so then suddenly the display turn off and the GPU fans start working at max
GPU Noise and fans video: https://photos.app.goo.gl/fwTkWo7WZKLsjRyP9
Use new GPU cable
