MSI B450M Pro-VDH Max and RTX 5060 TI 16 GB
ddd8e15a902da
I have a motherboard MSI B450M Pro-VDH Max (MS-7A38) (2 PCI-E x1, 1 PCI-E x16, 1 M.2, 4 DDR4 DIMM, Audio, Video, Gigabit LAN). I am thinking of installing an RTX 5060 TI 16 GB on it. I also have a Ryzen 5 3600 and 64 GB RAM. Will the RTX 5060 TI 16 GB fit on the MSI B450M Pro-VDH Max? Will there be any problems? Some people write that when installing the RTX 5060 TI 16 GB on some older B450 motherboards, the system does not boot, shows a black screen, or the system does not boot after installing drivers. Will I have such problems? Which vendor of the RTX 5060 TI should I choose for purchase to install on the MSI B450M Pro-VDH Max?
I have DEEPCOOL MATREXX 50 MESH 4FS.
I have a Corsair RM550X, which is a very high-quality power supply. The Corsair RM550x Series fully modular power supplies with EPS12V connectors are made with top-quality components to provide 80 PLUS Gold efficient power to your PC, while operating almost silently.
My system has a Ryzen 5 3600, 64 GB of RAM, 2 SSDs, and 1 HDD, and I believe the Corsair RM550X is more than enough to power it. The Ryzen 5 3600 does not require a very powerful supply, and the RM550X is a reliable and quality unit.
5060Ti itself has a recommendation for a 600W unit. But I think you may be ok with this one.
So it should work, but your mileage may vary.
