msi b550 a pro does not work
kirilljosa160602ef
I installed a ryzen 5 5600x processor, did not start. I flashed the bios from a flash drive, it did not start. I flashed the bios through the programmer, it does not start. CPU indicator is on. When you remove the RAM, the RAM indicator lights up. what could be the problem?
fatedust
Survey Corps
FIRST LIEUTENANT
I guess you've successfully flashed to BIOS newer than 7C56vA4 to support your 5600X?
Do you have other RAM to try? I would suggest you start troubleshooting with only one stick of RAM in DIMMA2 slot first.
kirilljosa160602ef
I tried different ram sticks in different slots. it's not working.
