MSI B550i Edge Wifi + 5600X Override + offset
bius
PRIVATE FIRST CLASS
hey guys what's up?
I need suggestions. I had a ryzen 5 3600 and on my UEFI i set overclock manual (multiplier and vcore + negative offset) and everything worked perfectly. the voltages on IDLE were the vcore - the offset value and under load, the voltage was the max value i set for vcore. example: vcore was 1.25v and negative offset of 0.05v. On IDLE the vcore was 1.2v and on load was 1.25v
Now I have a 5600x updated the bios to the latest version 1.71(from June 2021 with AGESA 1.2.0.3b) and chipset drivers up to date. Applied the same principle as mentioned above, but now my voltages always stay at the result of the vcore - offset
example: vcore is 1.3 and negative offset of 0.05. my voltages report is always ~1.25v idle and under load
is there something new on the bios for ryzen 5000 series that i need to change to get the same results as before?
bius
PRIVATE FIRST CLASS
- update -
tried only offset option and also the same as before the final voltage reported is the vcore - offset.
any suggestions? i don't want to enable PBO is too aggressive on the voltages
bius
PRIVATE FIRST CLASS
