Just to make sure I understand you correctly. Your system set to UEFI and M.2 system drive formatted with GPT was working. Then M.2 disks were no longer showing in BIOS. Did you notice this because the system would not boot after which you went into the BIOS?
If the RX550 worked with the motherboard in UEFI mode then I expect it to work in CSM mode as well. With the RX500 series it is often the case they only support CSM mode. They then need to be patched to provide GOP support to work with UEFI. Looking at the GPU is very likely a red herring.
The EZ Debug LED hangs at BOOT. This means it has problems seeing the M.2 disks as you also saw in the BIOS. What happens when you remove the M.2 disks? Does your system POST and are you able to enter the BIOS/
Thank you very much for your response. I will explain from the begining.
Yesterday only I assembled the PC with Ryzen7 5700X, MSI B550 Pro VDH WiFi, Samsung 2 X 8GB 3200 DDR4 (used one), M.2 NVME 512GB (used one), Dell RX550 OEM Graphics Card (used one), Deepcool PL550D 550WPSU, Deepcool AG400 cooler,
Circle Amazer X1 Mid- Tower Computer Case.
I built it for my wife as she learning basics of Blender. Due to budget constrain I decided to start with RX550 GPU and later will upgrade to a better one for Blender. My cousin got the used part from his friends.
Post assebly I connected the DP cable to the RX550 out and connected to my existing Samsung 24 monitor. Post few seconds BIOS loaded and CPU & RAM were showing; however M.2 SSD was not showing. So I thought that it was due to UEFI boot and I changed it to CSM in BIOS and restarted. Post restart nothing was displaying. I tried doing BIOS reset by removing CMOS battery, jumping JBAT1 pins. Then I did BIOS update by connecting pendrive, but no display still. In the motherboard BIOS light is ON.
I read in some posts that since Dell RX550 was an Dell OEM Graphics Card it might be locked only to UEFI mode. I can still see that the graphic card fan is running and PC also running but no output. Even I removed the M.2 SSDs but no postive result.
So, please suggest me, do I need to try with a different graphics card? or any other method to sort this like inserting a bootable win11 installed M.2?. I am totally worried :-(
I am attaching th initial BIOS screen pic and fault light pic for your reference.
