Hey forum, I just installed a newly bought msi big bang trinergy. Everything went according to plan except from the point where I installed the 4gb (2x2gb) ram dimms( I have the XMS3, 4gb kit by Corsair).
Let it be noted that i followed the instruction manual and installed the dimms in the proper slots. Then when the moment of truth came and powered up my pc, it wouldnt boot. It would go into an endless restart cycle without booting. Then i unplugged the dimm3 and started only using dimm1 and everything went well. I also switched the ram dimms (in case one of them was faulty) and placed it in dimm1 and again there was no problem.
My take on this situation is that there must be some hardware problem concerning DIMM3. I also run a BIOS update in hopes that something might change but no luck.
..So what is your take on this?
Thank you in advance for the advice.
P.S Since i had a P55 mobo before Big bang i read that format is not necessary so i didnt format the pc. Can that be the cause of the dual channel mal-function?
