MSI Center 2.0.42.0 and No Graphics Fan Tool!!!
lowdog
STAFF SERGEANT
When will this bug be fixed?
MSI Center ver 2.0.42.0 latest and under Feature Sets there is no option for Graphics Fan tool.
It used to be there in ver 2.0.34.0 but stopped working and if you clicked on Graphics Fan Control after installing it it would take you to the Mystic Light setting....WTF!
So now with the latest MSI Center the Graphics Fan Tool is not available under the Feature Set tab....why????????????????????????????
MSI Z790 ACE and MSI 4090 SUPRIM LIQUID.
Just tried again!.....uninstalled with the CleanCenterMaster and rebooted, installed latest MSI Center and same results...no Graphics Fan Tool in Feature Set.
Update:
That tool has been moved inside "Cooling Wizard", so use that one instead.
Having the same issue. Have done the steps as outlined above but with no luck.
Have everything up to date
MSI AMD 7900 XTX
MSI x570S Edge Max Wifi
AMD 5800X
Can use all other software to control fans speeds but no option inside MSI Center itself.
Yes, I have the same problem, I forgot how many times I uninstalled with CleanCenterMaster, deleted the MSI files and reinstalled. I tried to install from Microsoft Store many times, but it doesn't work in older versions; there is no Graphics Fan tool. I gave up now, I got used to it for 2 years, I loved using MSI center, but this error upset me. Please solve this error as soon as possible.
Also best add a screenshot from "Cooling Wizard" when you say that something isn't working or isn't there,
for best clarify.
Do you even see GPU temperature/frequency stuff under Hardware Monitoring?
And for graphics fan control, you cannot do that with MSI Center, only afterburner.
On my computer MSI Center's "Hardware Monitoring" is there but when clicked nothing shows up. Don't have mystic light or any other modules. The only thing working is the options menu, and once clicked I can't exit it. Latest updates have been problematic to me... To be honest I only use it because of mystic light but that's easy to replace. Don't feel like cleaning it and installing it every time an update comes up.
MSI B550 Pro VDH
As I said in my previous post, I tried everything that could be done, I forgot how many times I tried. The latest status in MSI CENTER is like the pictures in the attachment, there is no statement about GPU. Nothing about Graphics Fan Control is visible. Because it does not see the GPU. I hope it will be solved as soon as possible.
MSI confirms the latest AMD driver is causing the problem (24.9.1), roll back to older driver version or wait for new driver release from AMD.
MSI, en son AMD sürücüsünün (24.9.1) soruna neden olduğunu doğruladı; eski sürücü sürümüne geri dönün veya AMD'nin yeni sürücü sürümünü bekleyin.
I made a guess. Because whatever happened after 24.9.1.... thank you very much
