MSI Center 2.0.42.0 and No Graphics Fan Tool!!!
lowdog
STAFF SERGEANT
When will this bug be fixed?
MSI Center ver 2.0.42.0 latest and under Feature Sets there is no option for Graphics Fan tool.
It used to be there in ver 2.0.34.0 but stopped working and if you clicked on Graphics Fan Control after installing it it would take you to the Mystic Light setting....WTF!
So now with the latest MSI Center the Graphics Fan Tool is not available under the Feature Set tab....why????????????????????????????
MSI Z790 ACE and MSI 4090 SUPRIM LIQUID.
Is anyone else have issues with the MSI Cooling Wizard not engaging the fan controls unless you open the MSI Cooling Wizard? Once I open the Cooling Wizard then all my fans ramp down to where they should be running.
You can set it in BIOS instead. Did you install user scenario? How about MSI Center mode fan control? Does it work fine for you? (auto engage fan control without going into cooling wizard i mean)
Hello, can you share the screenshots of the vehicles you are having problems with the fans in MSI Center?
I uninstalled the Cooling Wizard and I'm only using the User Scenario and now the fans stay consistent with the settings that I have set. So the issue seems to be with the Cooling Wizard not engaging the settings when the PC boots up and after it wakes up from sleep mode.
MSI Center 2.0.44.0 ile benim için aynı.
AMD Yazılımı 24.20.11.05 sürümünü kullanırken bile.
Hello
I don't know your computer components but; the problem is not in MSI Center 2.0.44.0 and AMD Software 24.20.11.05 versions. The only problem is in AMD 24.10.1 version. For this, uninstall MSI CENTER with Clean Center Master, and also uninstall AMD Software and driver. Delete all files related to MSI and AMD from your computer and restart the PC. First install AMD Software 24.20.11.05 version (do not install 24.10.1 version) then install MSI Center 2.0.44.0, be sure your problem will be solved. After doing this, do not update AMD Software 24.20.11.05 until you solve the problem related to MSI CENTER as explained in AMD driver update; because the problem continues on AMD side.
MSI center did not see my graphics card either; It was not visible in neither cooling wizard nor Mystic Light. I have been experiencing this problem since versions 24.8.1 and 2.0.40.0.
I am using AMD Software version 24.20.11.05 without any problems on versions 2.0.42.0 - 2.0.43.0 - 2.0.44.0.
Hello
Thanks for reply.
Not working again on AMD 25.3.1 latest driver.
"Cooling Wizard" does not open.
Even "Mystic Light" not working. It opens, but do not change light configs.
Yes, unfortunately the situation is the same for me, I have 25.3.1 and MSI center 2.0.50.0 versions. It does not work with older versions; I try and delete and reinstall. The situation is the same and does not change. If there is any development, I will share it.
The issue is duplicated and AMD is noted about the issue.
Be patient for a solution, until then the temporary workaround is to use early driver v25.2.1
Thank you. Yes, as you said, AMD 25.2.1 is currently working with all the features of MSI center 2.0.50.0, no problem. Now we will wait for the next version for AMD.
Update:
FYI Adrenalin 25.4.1 is expected to be released on 4/17 and that should fix this issue.
Until then stick to 25.2.1 or previous version for now.
Could please provide the specific post about this issue?
If mean for updates for this issue, in the current topic I post updates when I have such.
Hello
Unfortunately, the same problem persists in AMD 25.3.2. The cooling wizard in MSI CENTER 2.0.50.2 does not work. I deleted all of them and reinstalled them, the problem persists. For your information.
