MSI Center 2.0.42.0 and No Graphics Fan Tool!!!
lowdog
STAFF SERGEANT
When will this bug be fixed?
MSI Center ver 2.0.42.0 latest and under Feature Sets there is no option for Graphics Fan tool.
It used to be there in ver 2.0.34.0 but stopped working and if you clicked on Graphics Fan Control after installing it it would take you to the Mystic Light setting....WTF!
So now with the latest MSI Center the Graphics Fan Tool is not available under the Feature Set tab....why????????????????????????????
MSI Z790 ACE and MSI 4090 SUPRIM LIQUID.
stick to old driver and update driver after 4/17
Hello again, MSI Center 2.0.53.0 cooling wizard is not working, AMD software 25.4.1 is installed, it does not see the GPU. Why is this happening? Although it is correct in one version, there is no compatibility in 2-3 versions, there is no method left that it has not tried. I did as in the old topics, I cannot run my PC case in silent mode in MSI Center.... Help me now, please
Now "Cooling Wizard" is working again on AMD 25.5.1 latest WHQL Recommended driver.
However, "Mystic Light" is still not working. It opens, but do not change light configs.
HelloI installed AMD 25.5.1, previously MSI Center 2.0.53.0 was installed but the cooling wizard was not working properly; so I deleted and removed its files and installed it again. This time it saw the GPU but the tools in MSI Center are not loading no matter what I did; it says downloading but waiting, it is not loading....Please help...
Regarding the subject I explained above, when I run MSI Center from the installed applications after repairing it, I get this warning, the photo is attached. MSI CENTER is currently disabled.
If you first install AMD 25.5.1 on the computer and then install MSI Center 25.0.53.0, MSI Center tools do not install and give an error saying Msı.centralserver.exe is not working. But if we install MSI Center first and then install AMD Software, this time it does not see the GPU, the cooling wizard, etc. tools do not work properly.. For your information
Here is working "half" properly as i said.
I installed AMD 25.5.1 with lastest MSI Center (2.0.52.0) already installed.
"Cooling Wizard" is now working.
Waiting for solution.
For now, i'll give a try this: https://github.com/ixjf/MSIRGB.
I don't use any MSI Center features, except for Mystic Light, so, i'll try this app just to configure the light.
EDIT:
Tested and it (MSIRGB app) works only with motherboards.
I want to control GPU light.
Yep, the new driver 25.5.1 and Mystic Light still fails :bonk:
MSI people feedback this to AMD and they are waiting from update from AMD.
That's true.
Same here.
Intalled MSI 2.0.53.0 now and the same behavior.
I can't install any features.
Same message "downloading but waiting" but it doesn't download anything.
I switched back to AMD 25.2.1 and Mystic Light is working well with MSI 2.0.53.0.
The way is to wait for a new update from AMD to change driver from 25.2.1 version.
