MSI Center 2.0.42.0 and No Graphics Fan Tool!!!
lowdog
STAFF SERGEANT
When will this bug be fixed?
MSI Center ver 2.0.42.0 latest and under Feature Sets there is no option for Graphics Fan tool.
It used to be there in ver 2.0.34.0 but stopped working and if you clicked on Graphics Fan Control after installing it it would take you to the Mystic Light setting....WTF!
So now with the latest MSI Center the Graphics Fan Tool is not available under the Feature Set tab....why????????????????????????????
MSI Z790 ACE and MSI 4090 SUPRIM LIQUID.
I had problems with the incompatibility of AMD driver and MSI Center and shared them on this page. I understand the mood and thoughts of gugabf. I have not had any problems with the drivers for 2-3 versions (both AMD and MSI Center). I discovered that the problem was caused by a 3rd software. I also use CPU - GPU temperature monitoring software connected to the USB port on the motherboard of the computer case. I am currently using Adrenalin 25.6.3 and MSI Center 2.0.55.0 versions, no problem, they all work without any problems. For this, first I delete the software of the PC case up to its file and uninstall the application. I also uninstall the AMD and MSI Center applications along with their files. First I install the AMD driver, then the MSI Center driver, restart the PC. Finally, I install the 3rd software. The problem goes away.
Dear gugabf, if you also have a 3rd software that you follow the PC temperature values, you can try the method I explained above. Let me even say that I had problems with the latest drivers of the 3rd software, and I am using the old versions of that too; after all, it is just a tracking program, it does not affect performance. I hope this information helps.
Thanks for the tips.
No, I don't have any 3rd party software that tracks PC temperature values and no USB device/controller connected that does this task.
I don't have MSI motherboard, but just MSI GPU.
So, i don't use any MSI Center features, except for Mystic Light to control GPU light (i just install "Cooling Wizard" and "Mystic Light" features).
Since AMD 25.5.1 (WHQL Recommended) driver, "Cooling Wizard" is working without issues.
However, "Mystic Light" doesn't work. It opens, but do not change light configs of my GPU.
I didn't test AMD 25.6.3, because i install only WHQL Recommended versions, and "Mystic Light" is still not working on AMD 25.6.1.
I always test doing a "CleanCenterMaster" and "MSICenterUninstaller" first, and installing first AMD driver and then the MSI Center driver.
Updated to AMD 25.8.1 and "Mystic Light" still doesn't work.
MSI Center 2.0.57.0.
It's regrettable.
Updated MSI Center to 2.0.58.0 (AMD 25.8.1 already installed) and "Mystic Light" still doesn't work.
Just reporting.
Updated AMD to 25.9.1 and "Mystic Light" still doesn't work for me.
I use Mystic Light just to control my GPU (MSI RX 5700 XT GAMING X) light.
AMD 25.2.1 was the last AMD driver version in which Mystic Light worked properly for me.
Previous AMD driver fixes issue with 7000 series GPU, for other graphics card, seems AMD is taking forever to get things done.
Has anyone tested AMD 25.10.2 with MSI Center 2.0.61.0 to see if it solved the problem?
EDIT:
I tested version AMD 25.11.1 with MSI Center 2.0.61.0 and it doesn't work.
The problem persists.
For me, AMD 25.2.1 is no longer indicating that a driver update is available. It used to say so, but now it says it's up to date.
It must be because they haven't solved that problem yet.
Mystic Light is now working on my AMD 5000 series GPU (MSI RX 5700 XT GAMING X) on AMD 25.11.1 driver version.
Updated MSI Center to 2.0.62.0 (with Mystic Light module 3.0.26.4) and RGB control started working again with AMD 25.11.1.
Thanks to the MSI team for the solution and to @Svet for sharing it.
