MSI Center Crashing when using Mystic Light
duece_159e02e3
I just got this pc this week, but I don't think I was having this issue the other day. In the LED dropdown I have SELECT ALL, JRGB1, JARGB_V2_1, JARGB_V2_2, if I select either JARGB option it crashes instantly. I can select JRGB1 and SELECT ALL without issue. But changes only seem to take effect when SELECT ALL is selected. I'm pretty sure my pc applied an update to MSI Center today. Is anyone else having this issue or know of a fix?
Glad i came across this post bcz i share the very same problem with my new PC i built up few days ago. I installed the latest MSI Center hoping i can control all RGBs from there but unfortunately i can't pick any of JARBGs separate outputs to play with colors on MB-controlled fan individually since my program crashes few seconds later. Moreover, I can't change the color scheme on 4 PC case built-in via-controller fans even if i pick "SELECT ALL" LED option, it only results in swapping schemes for CPU fans and DRAM. Despite that they (4 fans) run some default color scheme i can't control indicating ARGB connection exists.
I think sth is buggy in latest msi mystic light program. I tried to reinstall the program as well as to disable Memory integrity toggle in Core isolation (within Device security board) to offguard the memory checks but in vain...
did you manage to sort the problem out?
does your SELECT ALL make color changes to all ARGB-controlled devices in your PC? bcz my JARGB_V2_3 (PC case fans) don't react on any combined color change and run default green color scheme no matter what...SELECT ALL seem not to apply to that very output
