MSI Center - how to get it running ?
Hi all
According to speccy I have a MSI MS-14L1 (U3E1)
When I click MSI Center
I get the User Account Control pop-up and click YES
(no image, could not take screenshot)
I get this (looks like it is installed)
I click EXIT , then click MSI Center again and the whole thing starts all over again.
Please advice.
Thanks
Sam
What actual version of MSI Center have you loaded? 2.0.69.0 released 20-4-2026 is the latest version.
If you've previously had MSI Center installed, you'll ideally need to run MSI Clean Center Master to completely expunge all traces of previous installations, then download the latest version of MSI Center.
Alternatively, you can after using Clean Center Master, just download the MSI App from the Windows Store and run it from there.
Thanks Saabilla. Before I posted this I downloaded the newest from the MSI Website.
Did run MSI Clean Center Master in the past, but will try again and report back.
