MSI Center - Mystic Light 'Hey Lucky' not working
madan.designer
I had bought the laptop just 2 hours back and tried to change colors using voice command 'Hey Mystic' but nothing happens. Tried uninstalling and reinstalling MSI Center but the issue is not resolved.
Laptop Model - MSI Pulse GL66 - 3070 GPU
Crazydonkey
SECOND LIEUTENANT
Did you enable voice command option?
For my opinion, I would like to use manual settings or hotkeys instead of voice commands.
madan.designer
But is there a way to fix the voice commands and make it to work? Yes I did enable the voice command option. Is it hardware related issue?
madan.designer
Nope. No solution is provided yet and the MSI isn't responding on the same. I fear it might be hardware issue.
D
Deleted member 962717
Guest
Are the sound drivers all installed in the system?
