MSI Center + Mystic Light(latest version 2.0.72.0 Issues Will not save settings on Load/Resume > X870E Godlike Max
nyx
Hello!
Now here's the fun.
1) I can set all my colors and settings hit apply totally close out msi center never open it again shut down boot up etc everything is perfectly fine the motherboard saves all the settings!
2) I can do the above but if reload MSI center + Mystic Light by the following 1) Fresh boot up in windows 2) Close the program and reload. It will just simple destroy all my prior presets revert them every single time....
3) If my monitors goto sleep and MSI center + Mystic Light shuts off all the rgb lights which is a lovely feature and I resume my monitors again all my previous settings = Destroyed.
This is highly annoying and needs to be fixed. Msi center + Mystic Light is not saving what I setup in any of the profiles there is no save button applying the settings to me it would seem auto saves it but it keeps reverting them every time it loads or wakes up from shutting down the lights. Everything is the latest version MSI Center2.0.72.0
So The settings and profiles are just each section a specific color chosen. I'll explain the various steps
1) Choose all sync = select baseline color this method everything is the same color and it will just reset to this every time so in effect there's no difference. However upon opening the msi center and mystic light it it will show the profile then when you try to close it, it will display Your Changes Have not been saved would you like to discard changes even though it's already applied to the motherboard.. When opening on Profile 1 any custom color changes on various parts like say the M.2 1 or the I/O cover or any other sections will revert back to "All sync color schema every time."
2) Customizing each section of the motherboard to different colors or patterns then opening it up will just reset it all as I described before.
3) Clicking To different profiles (even though that profile is loaded will keep saying !!!!) Closing Opening up will trigger reset. There is no specific save button only apply for each section or all sync. When you click apply the wheel will spin and apply the color to the motherboard.
Board: MSI X870E Godlike Max
Bios: 7E48v2A33
VGA: 2X RTX 5090 Astral OC WaterCooled Custom Loop EK 5090 Astral Blocks.
Riser Cable: N/A
PSU: Corsair HX1600i
CPU AMD 9950X3D2
Mem: 96GB 2X48GB Corsair DDR5 7000 Dominator Titanium @6200
HDD/SSD: 1 4TB SN850X 4x 8TB SN850X 1 4TB 870EVo 2x 2TB 870 Evo
Cooler: Custom Water Loop EK Magnitude AM5 Block
Mouse: Logitech G502-X
OC: None
OS Windows 11 Enterprise LTSC IOT 24H2
Display: 4x Gigabyte F032U2Pro 1x Asus PG32UCDM3 1x Asus PG34UCDN 1X Asus PG34UCDM 2X Corsair Xenon Edge
FYI:
The issue is duplicated and MSI people are working on a solution.
I will update this topic when such is available.
Thanks
