MSI CENTER of problems
aramartis
Mystic Light.
Cant get any Orange bright color with this software.
Worst.
Then every updates I lose my settings.
Worst.
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
can you get orange in other RGB software like openrgb or signalrgb? if no then don't think it's a mystic light-relevant issue
plutomate
MAJOR GENERAL
No one knows which devices you use, it's better to write system config.
MSI Center color palette is not very accurate from my experience, you need to try more (R,G,B) combination to find the color you want.
If you're saying orange, I'd recommend you set the (R,G,B) to (139, 30, 0). You can increase green a bit to make it brighter but it'll look more yellowish.
