Msi center problem
aleku12be02ab
After recent MSI center update I got wierd problem. After I close "Hardware Monitoring" tab and open it again temp and fan information just freezes. Before the update it worked fine, temp and fan speed information changed every second.
Raider GE77HX 12UGS
This problem appeared on the latest version 1.0.65.0 of MSI Center. There's no way to downgrade to a more stable version since it's a UWP app :(
You can use HWinfo to monitor the data that you want . It seems it is MSI center bug. Hope newer version will solve the problem.
It seems the problem is resolved in MSI Center 2.0.6.0.
I update the latest MSI Center and I do not encounter the problem anymore.
I updated to MSI Center 2.0.6.0. and hardware monitoring values "freeze". Reinstalled twice and the monitoring page still freezes especially upon waking from sleep. ???
System specs in signature.
Thank you, I will as soon as I return from vacation in a few days. I did not realize there was an update until today. Good to know there may be a solution to the MSI Center issue.
Updated to the current version of MSI Center and hardware monitoring values still "freeze" after waking from sleep. I guess the next version will fix it for me. This has been an inconvenience for me, not a problem.
Downey Rob
I tried to reproduce the behavior based on your information, and I did not have any freeze issues like you.
You might need to provide more information here.
1. Which laptop do you have?
2. You can provide a video of the issue for reference. Upload it to google drive and share the link.
I found a link to an older version of MSI Center namely 2.0.21.0 from 2020. I did a clean install and the issue has resolved. Thank you for looking into it.
