skialpin159202df
- Jan 12, 2025
Please reply to this email with specific issue you are experiencing. Hopefully this consolidated list can be made and will be seen my MSI and some fixes can be made. Please review previous posts and add, please don't repeat.
Update 18 January
1. From the launcher Fortnite does not launch correctly. Launching from windows works fine.
2. Lag is horrible in both the MSI Center M as well as the MSI Quick Action game bar when in game. Have to use these before launching game.
3. In Manual mode the TDP option should be a slider. Currently it only allows 8W, 17W and 30W. This negatively impacts battery life if you use more TDP than needed.
4. Launching games within MSI Center M does not allow any customization based on a game. It is simply a launcher. Please allow launcher customization based on TDP, custom button layout, etc.
5. The MSI Quick action bar, when it does display, sometimes does not allow interaction. Sometimes selection gets stuck on the brightness setting. This issue appears to be mitigated if you pause briefly before interacting with the Quick Action Bar.
6. Sometimes when you launch a game from the MSI Center M launcher, the game mode changes correctly. However, when you enter the game the A,B,X,Y buttons do not work nor does pressing the screen. The latest MSI Center M release might have fix this issue.
7. Fingerprint sensor usually doesn't work, 10% success rate. When it doesn’t work have to use pin
8. When you launch MSI Center M after startup or reboot you have to accept MSI Privacy Policy and MSI Services Terms of Use if you uncheck the "Allow MSI to collect, process, and use your product information in order to improve user experience" option under MSI Center M, Settings, General Settings. If you accept the policies and don't uncheck this box this issue doesn't occur. I don't want you to collect and process my information!
Update 18 January
