I am having an issue with the Control Mode and Lighting Switch options in MSI Quick Settings on my MSI Claw 8 AI+ A2VM Polar Tempest Edition.
Both options are greyed out and cannot be changed:
Control Mode – locked to Gamepad
Lighting Switch – locked in the On position
The other Quick Settings options are working correctly.
I have already performed a factory reset and also did a clean installation of Windows. I also installed MSI Center M from scratch.
The Claw now boots directly into Windows instead of launching into Xbox Full Screen Experience/Xbox Mode.
However, the problem still occurs.
My current software/firmware versions are:
BIOS: E1T52IMS.114
BIOS Date: 2026/09/07
Firmware: E1T52EMS1.1091204202509:10:47
MSI Center M: 3.0.60831.0
MSI Center M SDK: 3.0.2608.3101
I have attached a photo showing the options affected by this issue.
Is this a known issue with this version of MSI Center M, or is there something I need to enable in order to unlock the Control Mode and Lighting Switch options?
Thank you for any help.
UPDATE!!!
I found the solution!
The problem was caused by the Embedded Controller option in Quick Settings.
I removed the Embedded Controller tile from Quick Settings, but left the Embedded Controller itself enabled.
After removing the tile, you need to close MSI Quick Settings completely through Task Manager and then start it again. Alternatively, you can simply restart the entire device.
After doing this, both Control Mode and Lighting Switch became available again.
So, to be clear: the Embedded Controller itself should remain enabled - only its tile needs to be removed from Quick Settings.
It looks like this may be a bug with MSI Center M / MSI Quick Settings. Hopefully this helps anyone else experiencing the same issue.
BIOS: E1T52IMS.114
UPDATE!!!
