MSI Clutch GM51 Lightweight Wireless Mouse Backlight Problem
Pigius
Hello, after the last update of MSI Mystic Light, something happened with the backlight of the MSI Clutch GM51 Lightweight Wireless mouse, when turning on the computer, it stopped lighting up at all, only turning the mouse off and on helps, as well as when exiting sleep mode, sometimes the side backlight of the mouse stops working, please fix these problems :(
how did you set the light, does it make any difference if you set other RGB style?
and have you tried resetting the mouse, or reinstalling MSI Center?
Today I turned on the PC and the backlight worked fine, if something happens I will write to you and yes the backlight mode that I use is "rainbow":)
Hello, again today when the mouse came out of sleep mode, half of the side backlight just started to shine in one color :( I did not reinstall MSI Center and did not reset the mouse settings, since I am almost sure that this will not help, because I started having problems with the backlight immediately after installing the latest update for Mystic Light.
what about removing MSI Center and use only hardware control lighting? If it's still not working then it could be hardware problem, or some software potentially interfering with the mouse RGB
