haroldfordini15ca02ea
- Nov 26, 2022
Hi all! I want to increase my SSD storage on MSI Cubi-N. What should I buy for this?
1 x mSATA SSDI have Cubi-N, exactly like on photoView attachment 166166
Just bought Sabrent Rocket Q 1tb https://ssdrive.net/sabrent-rocket-q-1-tb and have problems with installation. It way longer than factory SSD.
Will buy external usb ssd. What is max speed on Cubi-N? USB 3.0?I would just go for an External USB SSD
Just buy from reliable sources, they are not too bad on price and have decent speed
Something like this I have several External USB SSD drives I use
USB 3.1 Gen 1 supports speeds of up to 5Gbit/s while USB 3.1 Gen 2 supports speeds of up to 10Gbit/s.Just send back m2 ssd, it even has bigger size (2280, I need 2230).
like i said its NOT A M.2 on that Cubi its a mSATA Drive that was the precursor to M.2 technology and they are not interchangeable.Just send back m2 ssd, it even has bigger size (2280, I need 2230).
Ya I looked but that is listed as an Optional extra so not sure if you had it or not or even where you would buy it from or the Price on oneIf somebody planned the same upgrade - the better way is to install SATA 2.5" SSD. The price will be better than USB or msata and the temperature will be lower. But you need to install extended case cover from the Cubi-N set. Also USB SSD minuses is that one from fast ports 3.1 gone to connect external storage.
