Msi Eclips and CORSAIR DOMINATOR TR3X6G1600C8D
aliawaiskhan
SECOND LIEUTENANT
Hello
I recently by my new RAM CORSAIR DOMINATOR TR3X6G1600C8D.where from i configure is it exactly 1600 bus speed?
waiting for your prompt reply
Ali
RemusM
Active member
LIEUTENANT COLONEL
http://www.corsair.com/_datasheets/TR3X6G1600C8D.pdf
SPD programmed at:
XMP 8-8-8-24 values at 1600MHz (Vdimm = 1.65V)
JEDEC standard 9-9-9-24 values at 1333MHz (Vdimm = 1.5V)
Every part is tested in Corsair's factory at 1600MHz, but your actual results may vary depending on the overclocking margin of your CPU and motherboard.
You need to enable the XMP profile, or to manually set the timings, voltage and the 'Memory Ratio' to 6 (presuming they run stable at 1600MHz with CAS=8 and 1.65V).
cheers
aliawaiskhan
SECOND LIEUTENANT
Firts of all thanks for reply....
Can you help me....step by step what should i do afte goes in BIOS SETUP.please
And after enable XMP as you say,s i dont know about it....from which software or in bios how i check my RAM is working on 1600
Waiting for your prompt reply
Ali
aliawaiskhan
SECOND LIEUTENANT
Thanks for help me...my problem is solve and my ram is now working on 1600bus speed.
1 little question in my mind.This ram is not in default 1600 bus.we over clock him then they reached at 1600?
Hackie
Almost Correct.
We are overclocking the motherboard (chipset bus) to reach 1600.
