-Moederboard -MSI eclipse .Bios versie 1.1
-Geheugen : Corsair TWIN3X 1600MHz DDR3, 6GB, 9 9 9 24 ?
-Videokaart :geforce 7600 GT XXX (yes I know oldie didnt have the money for a new GFX CARD
-Tagan 2-Force II Series 800W, ATX12V
-HD Veliciraptor 300 gb
Made some pics from the Bios
http://members.home.nl/darkreva/pc/Afbeelding416.jpg
Like you can see the adjusted Dram frequen is on 1600 mhz but the current speed is 1066 and after reboot it stays there
The memory I bought its working Voltage is 1.65 Volts but the mainboards says that it can damage the cpu if I set it at 1.65 volts so its still on AUTO (1.5v)
But like this the memory will never work at 1600 Mhz..
http://members.home.nl/darkreva/pc/Afbeelding417.jpg
Thnx..
for replying
) -Tagan 2-Force II Series 800W, ATX12V
Thnx..
for replying
(I had some similar issues with DDR2 being only 800's but marked as 1066's). Puzzled your DDR3 won't run @ 1333. I Don't have any other ideas for you to try.
