Msi Force GC20 issue
Nakaara
Heya, i'm having some issues with my Force GC20. It changed today to analog mode for no reason whatsoever and i cannot use it to play games on my pc anymore since it was always on default mode and i don't know how to switch it back to default mode or try to fix it i tried updating my drivers and plugging it back in several times but it just didn't work and i don't know how to fix it.
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
does the mode switch button work? if not you might need to contact MSI How to contact MSI
How to Select the Controller Mode
1. Default Mode
• Select this mode to use the default settings for the controller.
• The 1st and 2nd Mode LED indicators glow when this mode is selected.
2. Analog Mode
• Select this mode for DirectInput Analog Mode. Users are allowed to define the analog stick of the controller as their need.
• When Default Mode is selected, long press the Mode Switch Button for 3 seconds to select Analog Mode.
• The 1st and 3rd Mode LED indicators glow when this mode is selected.
3. Digital Mode
• Select this mode for DirectInput Digital Mode. Users are allowed to define the D-pad of the controller as their need.
• When Analog Mode is selected, short press the Mode Switch Button for 1 second to select Digital Mode.
• The 1st and 4th Mode LED indicators glow when this mode is selected.
4. Android Mode
• Select this mode while the controller is connected to an android device.
• When Digital Mode is selected, long press the Mode Switch Button for 3 seconds to select Android Mode.
• The 3rd and 4th Mode LED indicators glow when this mode is selected.
Nakaara
it does but it doesnt switch it to Default mode it only switches it between analog and digital and both of those modes don't even work with dark souls 3 since i mainly wanted to play that it didnt work i did try other games but it was the same they didnt work on both modes so now i'm just at a loss of what to do honestly.
Nakaara
Apologies for the late response i was busy with real life issues and completely forgot and remembered today. Back to the topic yes after holding it down for a few times it switched back to default mode i appreciate your help it works now tank you.
