- Dec 22, 2017
I'm having a problem using this controller, it's fine but after a while it starts malfunctioning and I have to reconnect it. What happens is, after a while, the analog sticks won't input full capacity. Like, in AC Origins, you will run as if you only were only pushing the analog stick a little bit and not fully until the end, you will walk instead of running. The only way to fix this is buy removing the USB cable and putting it back again, it will be fine for some time but then the problem comes back.
What can be causing this? Anyone else having this issue? I have Windows 10 Pro 64 bit.
