Wigglesnapper
- Aug 2, 2024
Monitor: G272QPF E2
GPU: RTX 2060
I'm having an issue with my monitor where setting the refresh rate to 180hz makes it so the output colour format swaps from "RGB" to "YCbCr422". The output dynamic range also swaps from "Full" to "Limited". I am also unable to swap the output colour depth from "8bpc" to "10bpc" (which for this monitor would be 8bpc + FRC I believe). When attempting to apply these settings at 180hz, the nvidia control panel just resets the values. At 165hz I can set it to RGB with full dynamic range with a colour depth of 8bpc - unable to set it to the 10bpc option though.
I have updated the driver of the monitor, reinstalled my GPU drivers, and power cycled the monitor. I am not running HDR. Also deleted custom ICC profiles and just using the profile provided by the driver update.
I would like to be able to use this monitor at 180hz, 8bpc + FRC, set to RGB with a Full Dynamic Range. Could this be an issue with the stock DisplayPort cable not having enough bandwidth? Only solution I can think of that I haven't tried yet.
GPU: RTX 2060
