MSI g272qpf e2 monitor no RGB only YCbCr at 180HZ
rasheeqmee15a202e6
I recently bought the MSI G272QPF E2. When running monitor at native resolution 1440p at 180HZ there is no RGB colour and full output dynamic range in nvidia control panel; only YCbCr and limited dynamic range options show. When setting custom resolution 1440p at 179HZ the RGB options are available. I have a 3060ti and I am using the included DP cable. Any idea what the problem is here?
I've updated the Timing settings, and you'll notice the changes compared to my previous post. Keep in mind, I'm only human and can only test so much to find the best settings for this monitor. I just wish the whole color bandwidth issue wasn't a problem at all for 180Hz in the first place.
Your a legend man, I just got this monitor and had this problem too. This completely fixed it. I made this account just to thank you.
(UPDATE TO THIS POST) Hi I wanted to jump on this as I am also using the same monitor the MSI G272QPF E2 and I am using 179hz but all my games still run 180hz. What you want to do is go to Nvidia Control Panel and go to change resolution and then click on Customise and when you do that right at the bottom it should say Create Custom Resolution click that and on the Display mode (as reported by windows) which is the top part change the Refresh rate (Hz) to 179 and enjoy the 180hz in game and also you will have RGB and Full with 8 bpc but the downfall to it (Sadly) you will lose the 10 bpc BUT! at least you still get RGB colour format and Full dynamic range plus with 179hz :) Also this works for Nvidia cards I don't know about AMD cards
on the the timing section leave that as automatic :)View attachment 194694
Hey, thanks a lot dude. I am grateful to you. Thanks, thanks, thanks. God bless u
