MSI gaming pro carbon max
benboy473
Anyone know how many case fans I can put on the gaming pro max mobo? I'm using a vampic 010m case, I plan on using MSI mag max F12A-H3.
You mean B450 GAMING PRO CARBON MAX WIFI?
It has four 4-pin system fan connectors, 4-pin water-pump-fan connector (can be used for a fan if there is no pump) and one 4-pin CPU fan connector (for the cpu cooler's fan but could power any fan). With an adapter you could use two or three fans per connector. More fans than you could fit in that case.
