Hi recently built a new pc.
Msi GD65 gaming (bios updated to 1AO)
i7 4790k
8GB corsair vengance
msi Gtx 970
win 7 64 home edition
Ok build went smooth had retailer update bios a while back to 1AO as i knew id go for the 4790k, everything is running great until i need a restart and the system goes through the normal shutting down then just hangs there.Reset switch won't work i have to actualy power off the system then reboot,But if i shutdown the system instead of restart everything is ok and boots normaly.Now i can get by just using the shutdown method but obviously something is not right.
I have double and triple checked cables and front panel connectors as i am using the little connector that comes with the mb for the front panel cables.
Any thoughts tx in advance
i7 4790k
msi Gtx 970
