MSI GE66 10UG GPU Fan Problem
1950135645
CORPORAL
i have the problem with gpu usage. gpu stays at 1620mhz (base clock) and 7000mhz Vram clock. since 10 days i was trying to fix the problem. finally i found the problem. msi central service(dragon center). when i disabled the ms center, the gpu works normally. But with central service the gpu again works anormally.
xoldix
I see that the cpu temperature is quite high ... mine reaches 97 degrees in some games ... is that normal ??
