MSI GE76 UG11. - Weird Graphics.
Mr.Emo
Hello.
I recently purchased a MSI GE76 and have been very happy so far. But the last week I've started to experience some bugs with the graphics. Not quite sure what causes it and that's why I've come here.
Suddenly graphics in videos etc gets this weird glare/shimmer red blue green. If I restart the computer it goes away.
I tried taking a screenshot thinking it would work, but after restart the colors are back to normal.
I tried using the MSI center about graphics drivers but it didn't download the latest ones so I downloaded Geforce Experience which gave me new drivers. Do you think this could be the problem?
badboy2k
Hello.
wipe the NVIDIA driver using DDU in safe mode and then install the Latest NVIDIA driver again to make sure your driver is not Bugging out on you. if it continues after you have done that then its usually the GPU's VRAM is Faulty so give DDU a try in safe mode and see if it stops happening.
Mr.Emo
Can I download the drivers through Geforce Experience or Nvidia site or should I use MSI center?
seba84_2005
Active member
PRIVATE FIRST CLASS
Latest true color is 4.4.15.0 Just install 4.4.8.0 and from task bar make update.
next3r
MAJOR
hi
you have instillation "exe" from TEMP or similar ?
documents/dragon/temp - updates
send pls this update here or "notebook forum" ;)
Mr.Emo
Allready have 4.4.8. But I don't think my issues has anything to do with these. I have used DDU and done a fresh install of drivers and will see if this helps.
Mr.Emo
Problem still persists. I've attached some photos from my camera. You can clearly see weird outlines on videos etc. The other photo is after I restart the pc at the exact same timestamp in the video. IMG_20211108_1919132.jpgIMG_20211108_1922171.jpg
I have done what you suggested, fresh install of drivers after running DDU. So the next item on the list is faulty VRAM?
next3r
MAJOR
Problem still persists. I've attached some photos from my camera. You can clearly see weird outlines on videos etc. The other photo is after I restart the pc at the exact same timestamp in the video. View attachment 153431View attachment 153432
but this is not a problem of true color.
this look like slow motion - low HZ "refresh rate" ?
Mr.Emo
Frame
Rate
350 fpsRefresh
Rate
360 HzPixels
Per Frame
16Pixels
Per Sec
5760
This is what I'm getting. Does look okay to me?
next3r
MAJOR
Frame
Rate
350 fpsRefresh
Rate
360 HzPixels
Per Frame
16Pixels
Per Sec
5760
1/1 - 360fps on 360hz "but this is probarly ok for this panel" :unsure:
possible try others tests "select is above on page from link" try find DEMO where is visible your problem ?
display problems - EC reset
//edit ,.,steps
EC reset ,.no AC / fully shutdown ,,.,.small hole on back-cover - 30s
after this plug AC ,.,.wait 5min .,,.run system
you must see different boot time or blinking diodes
"best is disable wifi before" and see this diode in reset
identical boot - no reset
Mr.Emo
I would think the problem would be visible on all the tests when the problem occurs. It is random and suddenly happens.
It goes away if I restart computer.
I'm not quite sure what triggers it yet.
Mr.Emo
Hello again.
Problem still persists and appears at random when scrolling through facebook or other pages. I can't say that I have noticed it being triggered elsewhere.
I try to run the OCCT tests for 3d and VRAM when the fault has occured but I am unable to find anything.
Any other ideas to try out?
Difficult so send it for repairs when I can't really locate what is wrong.
