MSI GE76 - User Scenario / Fan questions
yuriy.yurchuk
CORPORAL
Hi guys, updated BIOS, new version of MSI Center installed. A few questions for using "User scenario":
1. For CPU fan - is there a smaller option for a fan, than 2400 RPM? Or is it only 0, 2400 and above?
2. For custom curve - even if I put first couple dots to 0% - fan still runs to 2400 rpm at 45 and above Degrees. Feels like we are not in control there?
3. What is the good working temp for CPU for excel/browsing work? (e.g. if I keep it at 60, is it too much? 70?)
mimimaomao
The fan will spin when the temperature is raising to a level of temperature. it's normally on laptop
It's necessary to spin up the fan or your laptop will get more and more hot.
It's the basic fan setting and above the custom settings.
There are still some apps or programs operating in the background though you feel the workload is low.
It's better using Auto mode under the daily usage.
At 25% my fans run 1959-2008 rpm. Thats the lowest i can get. But cant even hear them at that level.
i have idle temp of 33c
seba84_2005
Active member
PRIVATE FIRST CLASS
In my laptop on these settings cpu fan don't spin to around 55c on cpu.
In idle i have 41c on cpu i7 11800h.
