Let's first start with the specs of the MSI GeForce? GTX 1070 GAMING X 8G:
Graphics Processing Unit
NVIDIA? GeForce? GTX 1070
Interface
PCI Express x16 3.0
Core Name
GP104-200
Cores
1920 Units
Core Clocks
1797 MHz / 1607 MHz (OC Mode)
1771 MHz / 1582 MHz (Gaming Mode)
1683 MHz / 1506 MHz (Silent Mode)
Memory Clock Speed
8108 MHz (OC Mode)
8008 MHz (Gaming Mode)
8008 MHz (Silent Mode)
Memory
8GB GDDR5 (256-bit)
Output
DisplayPort x 3 (Version 1.4) / HDMI (Version 2.0) / DL-DVI-D
HDCP Support
2.2
Power consumption
150 W
Power connectors
6-pin x 1, 8-pin x 1
Recommended PSU
500 W
Card Dimension(mm)
279 x 140 x 42 mm
Weight (Card / Package)
1094 g / 1687 g
Afterburner OC
Y
DirectX Version Support
12
OpenGL Version Support
4.5
Multi-GPU Technology
SLI, 2-Way
Maximum Displays
VR Ready
Y
G-SYNC? technology
Y
Adaptive Vertical Sync
Y
Digital Maximum Resolution
7680 x 4320
It is literally a beast of a card. It feels solid. The cooling capacity has really shocked me, It cann stay at around 60 degrees while gaming and it stays quiet too. Everything I needed it for.
[font="Segoe UI" "Helvetica Neue" "Liberation Sans" "Nimbus Sans L" Arial sans-serif]It is literally a beast of a card. It feels solid. The cooling capacity has really shocked me, It cann stay at around 60 degrees while gaming and it stays quiet too. Everything I needed it for.[/font]
Interface
PCI Express x16 3.0
Core Name
GP104-200
Cores
1920 Units
Core Clocks
Memory Clock Speed
8108 MHz (OC Mode)
Memory
8GB GDDR5 (256-bit)
Output
HDCP Support
2.2
Power consumption
150 W
Power connectors
Recommended PSU
500 W
Card Dimension(mm)
279 x 140 x 42 mm
1094 g / 1687 g
Afterburner OC
Y
12
4.5
SLI, 2-Way
Maximum Displays
VR Ready
Y
G-SYNC? technology
Y
Y
7680 x 4320
