REQUEST MSI GeForce GTX 1660 SUPER VENTUS OC – Correct Replacement Fans, Part Numbers & Thermal Pads
Describe your request
circsireclame
I'm hoping someone from MSI or someone familiar with this particular GPU can help me.
I own an MSI GeForce GTX 1660 SUPER VENTUS OC (non-XS version), purchased in the Netherlands approximately five years ago.
GPU identification:
  • Model: GeForce GTX 1660 SUPER VENTUS OC
  • MSI serial reference: 602-V375-390SB
  • Market: Netherlands / European Union
I'm planning to replace the original cooling fans, but I'm having difficulty finding reliable information about the exact replacement parts and the disassembly procedure.
I've searched the MSI forums and various online resources, but unfortunately couldn't find definitive answers for this specific model. I'm also aware that different regional versions or revisions may use different components.
My questions are:
1. Replacement fans
  • What are the exact original fan part numbers (P/N) for this GPU?
  • Which replacement fans are guaranteed to fit, including the connector type and cable length?
  • Are the fans interchangeable with those used on other MSI Ventus models, or are there revision-specific differences?
2. Fan shroud removal
  • I've physically inspected the card and couldn't identify any externally accessible screws securing the plastic fan shroud.
  • Are the shroud screws hidden underneath the heatsink or PCB?
  • Is it possible to remove the fan shroud without completely separating the heatsink from the PCB, perhaps by removing the four main spring-loaded mounting screws to gain access?
3. Thermal pads
  • What are the factory thermal-pad thicknesses for this specific card, particularly for the VRAM and VRM components?
  • Is there an official diagram showing the pad locations and dimensions?
  • Are the original thermal pads generally reusable if they remain intact after removing the heatsink?
My main concern is avoiding unnecessary damage or extended downtime. This is my only GPU, and I'd prefer to have all the correct replacement parts ready before disassembling it.
I'd particularly appreciate information based on the exact non-XS VENTUS OC model sold in the Netherlands, rather than specifications from similar but different MSI cards.
Any official MSI documentation, service information, part numbers or first-hand experience would be greatly appreciated.
Thank you in advance!
