raevy153d02dc
- Dec 4, 2024
I just recently got this card from Amazon along with a new Corsair HX1000i power supply.
The radiator and fans were too big to fit inside my case the way they arrived stock, so I took the fans off and mounted them on top of my computer case with the radiator screwed in under it.
It all seems to be nice and secure. I plugged the fans back in to the 4 pin connectors on the radiator and proceeded to install the new power supply.
When I turned on the system, I smelled and saw smoke, so I turned it off and looked inside the case. One of the 4 pin connectors coming off the radiator where one of the fans was plugged in had burned, and I am not sure why. The cables from the fans themselves seem fine.
I unplugged the cables from the radiator and instead plugged them in to the 4 pin fan connections on my motherboard, but only one of the fans is running and the other is stationary.
I have not changed anything regarding the card such as overclocking or messing with MSI Afterburner. Everything is stock, fresh out of the box.
What should I do here? Did the fan short out or break? Any idea why the cable on the radiator itself would burn?
Should I RMA the new card through Amazon or MSI?
