D
Deleted member 663924
Guest
try new cpu ratio - 42
ring - 39
edit
and "negative offset" for CORE /CACHE 100mV undervolt
if your this works in games - use this ,.,..when need fix for heavy load + add AVX offset "negative ratio "2" - 4.2ghz easy load / 4ghz heavy
+ FAN CURVE is critical "oem starts full spin - 94+" for coolerbooster .,.otherwise it probably wouldn't even make sense
example
20-30-50-60-100-100 - full fan speed around 90C
ring - 39
edit
example
