MSI GL75 9SD
clubbe156d02e3
Hi. I have an MSI GL75 9SD laptop with a red backlight, after a year of use, the paint from the buttons began to wear off. Is this a guarantee or not? And another question, is it possible to replace the keyboard with RGB from another model?
drek4
Active member
PRIVATE FIRST CLASS
I doubt that "wear" would be considered as a warranty issue.
You must install the same keyboard like you have now.
clickpt15c102eb
Sorry to steal your topic, but to not open another one i will say my concern here.
I have a Msi GL75 9SDK-215PT Laptop then i checked the processor temperatures is high, i did dissambled my laptop and i check the thermal stuff are dry. My question is: Which termal option i need to use there? It´s termal pads or termal paste?
If is needed a termal pads which size i need?
hchg
Active member
LIEUTENANT COLONEL
As long as the thermal pad can cover those components, then you're fine.
