MSi GT72 2QD power issues during gaming
markus_willems
My MSI GT72 2QD (unfortunately 2 month beyond guarentee) has following problem: During gaming, expacially newer, more hardwaredemanding games (e.g. For Honor, Mass Effect Andromeda) the notebook shuts down after random times as if there is no power. No blue- or blackscreen it suddenly goes off. Trying it without akku, with some different adapter, with new thermal paste, with a bios update the problem was not solved. Temperatures of GPU and CPU are around 70? celsius or deeper when the shutdown happens.
Following some treads here and in the german forum it seems to be a problem, which become more frequent the past two or three month without seeing any solution in the treads. But this frequency allows the question, if there is a more general then personal problem with notebooks of this  and someone might even get suspicious, when the same error pattern starts to get more frequent just after reaching the guarentee-time-limit.
So is there already an existing solution or at least any kind of diagnosis?
Use latest Help Desk to export the system info and post the text information in here.
I also would suggest checking those with AC mode. Because the problem might cause by your old battery which couldn?t provide enough power with heavy loading task.
I have had exactly the same problem.  The system will crash when playing anything graphically intensive.  However, less graphically intensive games (Steamworld Heist), or using Chrome, do not cause the problem.   It is frustrating, because logs in Afterburner and Windows event Viewer show nothing.  I have replaced my power adapter, updated the EC to the current version, to no avail.  Today the computer stopped recognizing both power adapters.  The Help Desk info for my system is listed below.  Any help would be greatly appreciated!
System Information
Serial Number:                FFFFFFFF
Product Name:                 GT72 2QE
OS:                           Microsoft Windows 10 Home 64-bit Ver.1607(OS build 14393.1066.amd64fre.rs1_release_sec.170327-1835)
Windows Product Key:          8HVX7
HDI Build:                    non-OEM
BIOS Version:                 E1781IMS.10T
BIOS Release Date:            2015/05/19
EC Version:                   N/A
CPU:                          Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz
Memory:                       32 GB @ 800 MHz
                               - 8192 MB, DDR3-1600, Kingston MSI16D3LS1KFG/8G
                               - 8192 MB, DDR3-1600, Kingston 99U5428-018.A00LF
Graphics:                     NVIDIA GeForce GTX 980M, 8192 MB
VBIOS Version:                84.04.22.00.0a,8388608
Drive:                        SSD, Intel Raid 0 Volume, 1863.04 GB
Drive:                        HDD, HGST HTS721010A9E630, 931.51 GB
Network:                      Intel(R) Dual Band Wireless-AC 7265
Network:                      Killer E2200 Gigabit Ethernet Controller
Network:                      Bluetooth Device (Personal Area Network)
SHIFT mode:                   None
Power Plan:                   Power Scheme GUID: 381b4222-f694-41f0-9685-ff5bb260df2e  (Balanced)
Programs and Features
SteelSeries Engine 3.8.5                                                              , 3.8.5                ,
Synaptics Pointing Device Driver                                                      , 19.3.4.57            ,
NVIDIA 3D Vision Driver 381.65                                                        , 381.65               , 20170415
NVIDIA Control Panel 381.65                                                           , 381.65               , 20170415
NVIDIA Graphics Driver 381.65                                                         , 381.65               , 20170415
NVIDIA GeForce Experience 3.5.0.70                                                    , 3.5.0.70             , 20170415
NVIDIA PhysX System Software 9.17.0329                                                , 9.17.0329            , 20170415
NVIDIA Update 24.0.0.0        , 24.0.0.0             , 20170415
NVIDIA HD Audio Driver 1.3.34.26                                                      , 1.3.34.26            , 20170415
NVIDIA Install Application                                                            , 2.1002.247.2107      , 20170415
NVIDIA Backend        , 24.0.0.0             , 20170415
NVIDIA Container        , 1.3                  , 20170415
NVIDIA LocalSystem Container                                                          , 1.3                  , 20170415
NVIDIA Message Bus for NvContainer                                                    , 1.3                  , 20170415
NVIDIA NetworkService Container                                                       , 1.3                  , 20170415
NVIDIA Session Container                                                              , 1.3                  , 20170415
NVIDIA User Container        , 1.3                  , 20170415
NVIDIA Display Container                                                              , 1.2                  , 20170415
NVIDIA Display Container LS                                                           , 1.2                  , 20170415
NVIDIA Display Watchdog Plugin                                                        , 1.2                  , 20170415
NVIDIA Display Session Container                                                      , 1.2                  , 20170415
NVIDIA Watchdog Plugin for NvContainer                                                , 1.3                  , 20170415
NVIDIA ShadowPlay 3.5.0.70                                                            , 3.5.0.70             , 20170415
NVIDIA Update Core        , 24.0.0.0             , 20170415
NVIDIA Virtual Audio 3.60.1                                                           , 3.60.1               , 20170415
MSI Afterburner 4.3.0        , 4.3.0                ,
Help Desk        , 1.0.1703.1001        , 20170415
NVIDIA Stereoscopic 3D Driver                                                         , 7.17.13.7500         ,
Realtek High Definition Audio Driver                                                  , 6.0.1.7904           ,
Microsoft OneDrive        , 17.3.6799.0327       ,
?Torrent        , 3.5.0.43580          ,
7-Zip 16.04 (x64)        , 16.04                ,
Logitech Gaming Software 8.85                                                         , 8.85.215             ,
TeamSpeak 3 Client        , 3.0.19               ,
Vulkan Run Time Libraries 1.0.42.1                                                    , 1.0.42.1             ,
Microsoft Visual C++ 2010  x64 Redistributable - 10.0.40219                           , 10.0.40219           , 20161011
Malwarebytes version 3.0.6.1469                                                       , 3.0.6.1469           , 20170411
UE4 Prerequisites (x64)                                                               , 1.0.11.0             , 20161226
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030                         , 11.0.61030           , 20160904
Microsoft Visual C++ 2015 x64 Minimum Runtime - 14.0.24215                            , 14.0.24215           , 20170304
iTunes        , 12.5.3.17            , 20161106
Apple Mobile Device Support                                                           , 10.0.1.3             , 20161106
Bonjour        , 3.1.0.1              , 20160929
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161                        , 9.0.30729.6161       , 20161027
Logitech Gaming Software                                                              , 8.30.28              , 20160829
paint.net        , 4.0.13               , 20170208
Microsoft Visual C++ 2005 Redistributable (x64)                                       , 8.0.59192            , 20161105
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.21005                         , 12.0.21005           , 20160829
Apple Application Support (64-bit)                                                    , 5.1                  , 20161106
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.50727                            , 11.0.50727           , 20170321
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.21005                            , 12.0.21005           , 20160829
ScpToolkit        , 1.6.238.16010        , 20161011
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.50727                         , 11.0.50727           , 20170321
Ansel        , 381.65               , 20170415
SHIELD Streaming        , 7.1.0360             , 20170415
NvNodejs        , 3.5.0.70             , 20170415
NvTelemetry        , 2.4.5.0              , 20170415
NvvHci        , 2.02.0.5             , 20170415
Nvidia Share        , 3.5.0.70             , 20170415
SHIELD Wireless Controller Driver                                                     , 3.5.0.70             , 20170415
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030                            , 11.0.61030           , 20160904
Microsoft Visual C++ 2015 x64 Additional Runtime - 14.0.24215                         , 14.0.24215           , 20170304
FlacSquisher 1.3.7        , 1.3.7                ,
Google Chrome        , 57.0.2987.133        , 20160830
HandBrake 1.0.1        , 1.0.1                ,
Origin        , 10.4.6.33873         ,
RivaTuner Statistics Server 6.5.0                                                     , 6.5.0                ,
Steam        , 2.10.91.91           ,
VLC media player        , 2.2.4                ,
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501                          , 12.0.30501.0         ,
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.21005                            , 12.0.21005           , 20160829
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.50727                          , 11.0.50727.1         ,
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.50727                          , 11.0.50727.1         ,
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.50727                            , 11.0.50727           , 20170321
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030                          , 11.0.61030.0         ,
Microsoft Games for Windows Marketplace                                               , 3.5.50.0             , 20161112
Mass Effect? 3        , 1.05.0.0             ,
Apple Software Update        , 2.2.0.150            , 20160929
Google Update Helper        , 1.3.33.3             , 20170411
Microsoft Visual C++ 2015 x86 Additional Runtime - 14.0.24215                         , 14.0.24215           , 20170304
Microsoft Visual C++ 2005 Redistributable                                             , 8.0.61001            , 20160920
Mass Effect?: Andromeda                                                              , 1.0.0.5              ,
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17                          , 9.0.30729            , 20170223
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161                        , 9.0.30729.6161       , 20161027
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030                         , 11.0.61030           , 20160904
Medieval CUE Splitter        , 1.2.0                , 20170225
Microsoft Visual C++ 2015 x86 Minimum Runtime - 14.0.24215                            , 14.0.24215           , 20170304
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030                            , 11.0.61030           , 20160904
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030                          , 11.0.61030.0         ,
Mechwarior Living Legends 0.8 Community Edition & Crysis Wars Trial 1.5 version 0.8.0 , 0.8.0                , 20161105
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24215                          , 14.0.24215.1         ,
Curse        , 6.0.0.0              , 20160904
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215                          , 14.0.24215.1         ,
Microsoft Visual C++ 2010  x86 Redistributable - 10.0.40219                           , 10.0.40219           , 20161011
Microsoft Games for Windows - LIVE Redistributable                                    , 3.5.88.0             , 20161112
Apple Application Support (32-bit)                                                    , 5.1                  , 20161106
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501                          , 12.0.30501.0         ,
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.21005                         , 12.0.21005           , 20160829
Skype? 7.31        , 7.31.104             , 20170122
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.50727                         , 11.0.50727           , 20170321
Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022                             , 9.0.21022            , 20161126
Windows Hotfix
KB3176936        , Update               , 20160829
KB3199209        , Update               , 20161020
KB3199986        , Update               , 20161028
KB3211320        , Update               , 20170125
KB4013418        , Update               , 20170315
KB4018483        , Security Update      , 20170413
KB4015217        , Security Update      , 20170413
OS Activation
Name: Windows(R), Core edition
Description: Windows(R) Operating System, RETAIL channel
Partial Product Key: 8HVX7
License Status: Licensed
It also happened before i installed afterburner. Afterburner was installed to have a better view on temperatures.
So, I took the notebook apart last night and cleaned everything.  Afterwards it would not power on.  This is similar to what I have experienced in the past.  This morning it powered on and recognized the power adapter.  The battery had charged fully.
After backing up some important stuff I started a game to test.  The computer switched to battery power immediately.  Restarts, EC reset, will not allow it to recognize the adapter again.  I have not allowed it to crash from within a game again.
I have seen that the VBIOS can be at fault for the crashing issue in another thread with regards to a GT72VR.  Is there a possibility that would be the case here?  Any help is appreciated.
Hi markus_willems,
Try with system recovery. If the problem is still happening with factory system, you might need to contact with MSI.
