tranzystorbipolarn156f02e1
- Dec 15, 2024
Is it possible to modify the firmware on this laptop so that you can use the battery protection feature in MSI Dragon Center by setting the charging interval between 70% and 80%, for example? Unfortunately, this feature does not work at the moment. I also checked it in RW-Everything v1.7 and it does not work either.
Best regards
Best regards
