MSI GTX 1060 3G
Status
Not open for further replies.
erikandronico
Hey guys this video card is awesome, i buyed it becouse nvidia told that this card was near to power of a gtx 980 and it is! so if u want to play on all games in full hd (1080p) or 2k (1440p), this video card is for you! and remember to buy the MSI edition becouse have the twin frozr VI that will cool ur graphic card and keep it near 60? degrees.
The below specifications represent this GPU as incorporated into NVIDIA's reference graphics card design. Clock specifications apply while gaming with medium to full GPU utilization. Graphics card specifications may vary by Add-in-card manufacturer. Please refer to the Add-in-card manufacturers' website for actual shipping specifications.
GPU Engine Specs
CUDA Cores
1280
Graphics Clock (MHz)
1506
Processor Clock (MHz)
1708
Graphics Performance
high-11048
Memory Specs
Standard Memory Config
6 GB
Memory Interface
GDDR5
Memory Interface Width
192-bit
Memory Bandwidth (GB/sec)
192
Feature Support
Supported Technologies
CUDA, 3D Vision, PhysX, NVIDIA G-SYNC?, GameStream, Surround, ShadowWorks, MFAA, DSR, DirectX 12, Virtual Reality, Ansel
Display Support
Maximum Digital Resolution
7680x4320@60Hz
Standard Display Connectors
DP 1.43, HDMI 2.0b, Dual Link-DVI
Standard Graphics Card Dimensions
Length
9.823
Height
4.378
Width
2-Slot
Thermal and Power Specs
Maximum GPU Temperature (in C)
94
Maximum Graphics Card Power (W)
120 W
Minimum System Power Requirement (W)
400 W
Supplementary Power Connectors
6-Pin
Zero Frozr-Stay undetected
 First introduced in 2008 by MSI, ZeroFrozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
Catch the Vibe with Cool LED Effects
 Each LED can be controlled individually by choosing any of the animation effects availiable in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
 HEATSINK
 Lurking under the cover of the GAMING graphics card is an engineering masterpiece designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool & quiet gaming experience.
 Airflow Control Technology
 Using advanced aerodynamics, Airflow Control Technology directs more air directly onto the TWIN FROZR VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming.
rossgunn21
PRIVATE FIRST CLASS
very nice review i almost got the exact same card but took the plunge and paid extra for the 6gb armour and agreed MIS make great graphic cards
11696ron
I've thought of buying one because of the value but there's something about having a 1080 or a 1080ti that makes you feel so much better.
jcioffi88
STAFF SERGEANT
Cool card. wish I could say the same for your wire management though
Status
