MSI GTX 770 LIGHTNING - CODE 43
kaastrup
Hi please help...:hypocrite:
I have installed this card in different pc?s, but I keep ending up with windows reporting code 43 - can not start driver.
The think is that I can change resolution, there is no graphic fault on my display, and every think looks fine. If I use DDU to clean nvidia drivers, and reboot then windows 10 reports Microsoft Basic Driver with no error codes...But as soon as I try installing some version of the nvidia drivers, I get the code 43 with yellow exclamation mark. I have tried the newest drivers with and without Geforce Experience, and I have tried some of the older drivers, where I first unzipped the package and then updated the drivers manualy.....
I can update both normal and LN2 vbios via nvflash64 with success, and I have tried different versions now, but still the same error code 43 loading drivers.
The problem is that ex. GPU-Z reports only part of the numbers etc...see attachments
Is my card broken or what ???
It is frustrating to have no display errors but still not be able to load a driver...
As it happens in various pcs you can be pretty sure that the card is somehow defective.
