MSI GX620 bios flash fail.
Bose321
PRIVATE FIRST CLASS
I've download  the update and put it on my usb stick. Then i boot from it, then it says bootmgr is missing. The reason why i want to update is because my keyboard randomly stops working. Please help me, because i need it for school, so i cant really send it back...
Administrator
you are trying to boot from wrong drive or the USB stick is not bootable.
Bose321
PRIVATE FIRST CLASS
I've used it several times to flash stuff on my PC, and i'm sure i've selected the right thing...
Administrator
Enter in BIOS and reverse HDD boot priority to ensure that you are booting from the right storage
You are booting from the wrong drive or your USB key is NTFS formatted and not bootable.
Bose321
PRIVATE FIRST CLASS
It's NTFS formatted. I used that hp program. is NTFS  wrong?
Bose321
PRIVATE FIRST CLASS
when i use the 2nd option, it formats about 75%, then it says bad volume tabel...
Administrator
seems something is wrong with your USB key since can't be formatted, try with another one
Bose321
PRIVATE FIRST CLASS
I dont have another one. i changed the name of it. and it formatted.
FYI, im trying to update the firmware. not bios.
Administrator
kk
:yes:
Bose321
PRIVATE FIRST CLASS
So, now i put the 3 files of the zip in the usb stick and boot from it?
Administrator
Yes, but make the USB key bootable 1st.
Bose321
PRIVATE FIRST CLASS
i follow stop 1 till 10. So it should be  bootable...
Administrator
go ahead then, after booting from the usb key, type "flash" {without quotes and press ENTER}  and wait to finish.
Once done, do EC Reset ==> https://forum-en.msi.com/index.php?topic=112416.0
Bose321
PRIVATE FIRST CLASS
Okay, It's succesfull.  No errors or whatsoever. I'll now test and see if the keyboard keeps working. thanks alot mate.
