MSI H610M-E DDR4 The sound does not work after the update
omezi156702da
I repair motherboards in Russia, a lot of boards come after the BIOS update on which the sound stops working. But rolling back to previous versions through the programmer does not help. The only way to make the sound work again is to change the chipset with a new chipset and the sound starts working with any firmware. Also, if you put this chipset on another H610 board from ASUS GIGABYTE ASRock, there is also no sound. Incorrect firmware somehow disables the chipset. The problem is that the chipset does not reset the audio codec, I tried to force it to be removed, but it also does not work. This massive problem occurs for users after updating the BIOS, the sound disappears in the task manager or hangs on the VGA post code, but after firmware on the programmer we also get a non-working sound. Solve the problem in Russia, they refuse to accept these warranty cards because they blame the user for incorrectly updating the bios. I'm sure there's a firmware that will fix it somehow.
I even made a video about it a long time ago.
For Audio recovery
We would like you to try this method first.
Make sure to flash back to the previous working BIOS first
This will be on your motherboard support page
The second-to-last bios released in 2023 will be the one you want
Flashing to this BIOS will not void the warranty
If the BIOS recovers the audio, follow the steps below
Roll back to the last working bios and then update the BIOS with the Svet BIOS update tool. This has worked so far without the need for the other patched Bios to be used.
Download the tool from the link:
https://forum-en.msi.com/index.php?threads/forum-uefi-shell-flash-tool-v1-81-for-msi-boards-%E2%9C%94.343010/
i need too
